Edited by Bogaber, 21 May 2010 - 07:19 PM.
Posted 21 May 2010 - 10:39 AM
Posted 21 May 2010 - 11:24 AM
Posted 21 May 2010 - 11:51 AM
This is not a contribution to the answer. However, I feel it is important, and I take this opportunity before my good friend Guido reads this post. The correct and accurate identity of the equation you refer to is The van der Waals Equation. It is such an important and critical milestone in the history of engineering that I felt I should make this statement. It is the pioneering Equation Of State, formulated by and derived by a great figure in the history of physics and engineering in 1873: Johannes Diderik van der Waals.
The mere mention of his name should make all process and project engineers stop and contemplate his accomplishments in awe. That's why I make note of the correct spelling of his name and legacy.
Posted 21 May 2010 - 01:18 PM
Posted 21 May 2010 - 01:53 PM
Edited by latexman, 21 May 2010 - 01:56 PM.
Posted 21 May 2010 - 04:34 PM
P=(RT/(v-β))-a/v^2 is correctly written (b was substituted by β to avoid "yellow face"), transformed as below:I have a homework, and it is required to calculate the volume using Van Der Walls Equation, I did some rearangement in the equation P=(RT/v-β)-(a/V^2), and I got this equation (1/a)V^2-(1/RT)V+((βP+RT)/RTP)=0. I solved for V, but the problem was that I didn't get the answer, because a square root of a minus value doesn't give a solution. Could you please show me what was the mistake ?
Edited by kkala, 21 May 2010 - 05:12 PM.
Posted 21 May 2010 - 05:42 PM
Posted 22 May 2010 - 03:00 AM
Posted 22 May 2010 - 09:40 AM
![]() Construction Management Student - How Thick Are Cooling Tower Walls?Started by Guest_-ed-_* , 16 Sep 2008 |
