We are exporting propylene from our refinery, almost in a continuous manner. The produced propylene is temporarily stored in a tank with a constant inlet flowrate (approx. +5 deg C, 2 bar g storage conditions and 150 ppm water dissolved) and exported once a week.
In order to meet the product spec. we need to reduce the water content down to 60 ppm or less. At the moment we are pumping the propylene throuhg a salt bed that dissolves the water. The water level in the salt dryer is kept to the lowest feasible point (less than 5%). However, we are experiencing a number of operational problems, and have observed that there is channeling in the salt bed, with small chunks of salt ending up at the export point further downstream. The salt beds are not insulated, and our plant is in scandinavia.
We have a coalescer installed upstream the salt beds to separate any free water, but no water is accumulated in the boot.
We are using up 3 to 4 times more salt than the original design documentation states and this is quite costly. We believe that the channeling effect and the higher salt consumption problems are related.
Has any of you experienced the same problem or have any good piece of advice?
Any comments will be appreciated!
Edited by herrani, 01 June 2010 - 02:00 AM.
