Steam Ejector Question
#1 deltaChe
deltaChe
  • 153 posts
Posted 03 June 2010 - 08:11 AM
I have a steam ejector and interlock (671-I-017)
to stop pulling vacuum to reactor.
Any these event happen, XV-065 opened and XV-066 opened and XV-060 opened,
it will stop pulling vacuum to reactor
As XV-060 closed (steam to ejectors - main valve)
, 677-PALL-015 actuated (MRS header pressure)
It will result that XV-061 (steam to first ejector)
, XV-062 (steam to second ejector), and XV-064 (nitrogen to adjust vacuum)
all close, PIC-065 manual, close PV-065
XV065 (vacuum line) and XV-066 (vacuum line) all close
Could any explain more detail about ejector working philosphy or physical phenomena?
Thank you very much.
  • Attached File  tt.pdf   26.01KB   38 downloads
#2 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 03 June 2010 - 08:28 AM
hswang2,
Have you ever tried using the search feature of the forum? Many of the questions that you ask would get answered from the more than ten thousand posts already existing on the forum.
Amongst others there have been innumerable posts on steam ejectors. Try out the search feature you should definitely get tour answer.
#3 breizh
  • 6,773 posts
Posted 04 June 2010 - 01:23 AM
Let you follow Ankur's suggestion , so many posts are available on this forum . BTW did you try Google ?
Attached a good reference :
http://www.graham-mf...x.asp?pageId=48
#4 Zauberberg
Zauberberg
  • 2,728 posts
Posted 10 June 2010 - 04:50 AM
Quality information regarding ejector systems can be downloaded at:
http://www.graham-mf...ibVacuum/23.PDF
http://www.graham-mf...bVacuum/210.PDF
http://www.graham-mf...bVacuum/213.PDF
http://www.graham-mf...bVacuum/216.PDF
http://www.graham-mf...bVacuum/217.PDF
http://www.graham-mf...bVacuum/221.PDF
