Solenoids Valve Interlock Question
#1 deltaChe
deltaChe
  • 153 posts
Posted 10 June 2010 - 09:23 AM
I have a solenoids valve actuated diagram which I don't quite understand( pls see the attached test 1 and test 2pdf)
The first type solenoid valve have two limit switch HZSC and HZSO
which seems to be used as permissives initiators in the DCS interlock.
But, I don't know how to decide it is position switch or open/close limit switch.
The second type solenod valve have XZSC and XZSO limit switch which
seems to be used as permissives initiators in a safety interlock.
And, it seems have two soft link commands from the DCS used as
reset and open/close swtich.
But, I don't know what is the difference of the two type valve.
And, ome more question is that do I have to count these HZSC, XZSC
as an input signal and put on the cause part on the cause & effect table.
Could any master in I&C and process engineering field explain detail
to me?
Thank you very much.
#2 rizaldi
rizaldi
  • 3 posts
Posted 10 June 2010 - 10:56 AM
to me?
Those ZSC and ZSO usually stand for device/transmitter that send information about your SDV/BDV position open or close.
ZSO for open and ZSC for close. I think no need to put as input signal in Cause and Effect.
I'm a newbie here, please CMIIW.
regards,
-rzd-
#3 demank
demank
  • 150 posts
Posted 10 June 2010 - 07:45 PM
Agree with Rizaldi say.
Btw2, the data that you provide is not enough,
Is it BDV, Is it SDV? or just on/off valve. Or any valve arrangement that need interlock from those valves.
For BDV/SDV stand-alone, I think Switch Open/Close just for indicator only, no trigger to other device.
