My question is follwing
N1. Refer from control loop naritive, this loop FIC-030 is to assure a correct feeding quality
of nonyl phenol into reactor, in order to reach this goal, it is
required to provided a flow controller combined with totallizers.(?? why the engineer put
two totallizer on the same process line instead of putting one totallizer on the other DEG
feed process line-although it will close when nonyl phenol feed in)
N2.Which type totallizer is better?Vortex, positive displacement, turbine, coriolis-
although we use coriolis
N3. How the engineer to determine this coriolis type mass flow meter
should be used in this process from purpose of measurement point of view?
Actually I don't understand why they use totallizer instead of using common
type flow meter. (some books totallizer always used in ratio control
and it can verify the overall correctness of total blended product and
it has memory of the amount of past error but my case seems not ratio control)
Thank you very much your kindly help.
