We process engineer deign a pressure gauge installed on the process line (liquid phase, line pressure is min op= atm, normal op=1 barg,max op=12 barg, and design pressure=25 barg).
But, the I&C staff came to me and said this pressure gauge maximum op should be within the two third of the maximum full scale of the gauge. So in this case max op should be 2/3 X 12 barg=7.9barg instead of 12barg.
As I know every pressure gauge have an inherent over range generally 1.3 times the maximum full scale value of the gauge.
My question is how to fix the I&C staff problem to choose the appropriate pressure gauge and also meet process staff requirement max op=12 barg.(for example put two pressure gauge)
Thank you very much.
Edited by hswang2, 04 July 2010 - 12:08 AM.
