Hysys Simulation Problem
Posted 07 July 2010 - 11:44 AM
CH4+H2O = CO+3H2
CO+H2O = CO2+H2
CH4+2H2O = CO2+4H2
I use Plug Flow Reactor and other reactors. After I complete to put every variable,hysys is showed warning that " K-100 Overspecified "
And in each reactor box is showed " Not Solved ". How to solve this problem?
Thank you in advance.
Posted 09 July 2010 - 03:48 PM
That question is hard to answer without seeing your model, you may want to post it here, but take out any confidential info.I tried to run Methane Reforming Based Hydrogen Production by hysys. The reactions are:
CH4+H2O = CO+3H2
CO+H2O = CO2+H2
CH4+2H2O = CO2+4H2
Assuming that K-100 is your reactor, it looks like you gave Hysys more info than it needs. You typically want to specify inlet conditions, pressure drop, reaction data, and residence time data (or reactor dimensions), but not more than that.
Posted 13 July 2010 - 11:01 PM
You can find tutorial for H2 Production or Ammonia Production where these reactions are modeled. If you could tell us more about your model/configuration we could analyze and suggest accordingly. As 'Joerd' said that any unit operation to solve it need minimum inputs to be given by user (In other words the degrees of freedom)and others are calculated by Hysys, so just in case if specify more than required inputs it overrides the value calculated by Hysys so it gives you warning that the operation is 'over specified', by the time the Solver gets inactive and the same operation will warn you as 'Not Solved. So just build your model properly.
I could anticipate the probable reasons as below,
1.Is it an adiabatic reactor i.e. it has an energy stream attached, if not attached and specifying outlet temperature could warn you as over specified.
2.Inputting the DP across reactor(I assume that the inlet feed stream is converged or it has a pressure value)and again specifying the outlet pressure(if it doesn't matches) would give the same warning with solver becomes inactive depicting another new warning as 'Not Solved'.
Posted 14 July 2010 - 10:26 PM
I try to do my simulation again but still have the same problem.
I study in process control. This topic relates to my thesis.
I would appreciate it if you helped me solve this trouble.
My file is attached to this reply.
K-100 is the first combine.
Despite I put delta P, The first bump of the upper line is still showed "unknown delta P".
The other instruments are showed "not solve".
Edited by satank, 15 July 2010 - 12:32 AM.
Posted 22 July 2010 - 01:04 PM
Posted 28 July 2010 - 12:50 AM
Edited by satank, 28 July 2010 - 12:51 AM.
Posted 29 July 2010 - 12:48 AM
What I did to make it work:Thank you Joerd
1. Set all Heat Exchanger pressure drop to zero
2. Removed the composition in Stream 10
Anyway, I think that most probably this is not the system that you want to have in mind, but for the purpose of making it work, the above procedure suffices.
Posted 29 July 2010 - 06:59 AM
Thank you Joerd
Thank you very much Dacs
Lng ProblemStarted by Guest_guoyinyanliner_* , 10 Dec 2025 |
Thermosyphon Reboiler ProblemStarted by Guest_aliebrahem17_* , 22 Oct 2025 |
