Ro Downstream Of Isolation Valve
Posted 08 July 2010 - 12:11 AM
i am just going through one P&ID and i can see restriction orifice downstream of isolation valve( ball valve) . it is a pressurizing line so i guess the purpose is during pressurizing, the ball valve will be fully opened and RO downstream will restrict the flow according to its bore size. am i correct?? what if this RO is upstream of isolation valve???
thanks in advance..
Posted 08 July 2010 - 02:52 AM
Hi All,
thanks in advance..
Without having adequate information about the relevant process and fluid couldn't be able to submit considerable assistance.
Anyway,if isolation valve and RO is located before a vessel (in the by pass line of main valve) seems you are right and they would be there for pressurizing.
I think the RO should be located downstream of the valve,unless the valve would be provided with hard trim against high fluid velocity.
Posted 08 July 2010 - 06:23 AM
Hi All,
thanks in advance..
yes, isolation valve and RO located upstream of pressure vessel and its a by-pass line( hydrocarbon gas) of the main shutdown valve.
what if RO is at upstream of isolation valve?? will it effect during pressurization as RO will give a constant minimum flow .
Posted 08 July 2010 - 07:23 AM
-Low temperature then requires a valve with different specs and more expensive to cover a broad range of temperature
-condensation on the valve give rise to extra problems of stuck up, related to stem.
Even valve at u/s is provided at a specified distance from restriction RO.
Posted 12 July 2010 - 01:55 AM
Automatic Choke ValveStarted by Guest_Mudassssir011_* , 22 Jul 2025 |
Parallel Control Valves Downstream Relief ScenarioStarted by Guest_pklavinsJ_* , 18 Jun 2025 |
