Hydrate- Temp Depression
			Posted 29 July 2010 - 11:18 PM
Based on the hydrate formation temperature arrived from hysys , I had calculated the temp. to be depressed by using inhibitor.
Based on the Hammerschmidt equation & Nielsen-Bucklin Equation , the injection rate of Methanol and MEG is calculated manually.
When I feed the same rate in the Hysys , the temperature is not depressed for the calculated flow rate for the both Methanol & MEG.
Please suggest how to rectify.
Stu
			Posted 30 July 2010 - 12:06 PM
At higher natural gas pressures, HYSYS tends to underpredict the hydrate formation temperature. Some experts in the gas processing field consider hydrate formation conditions as predicted by the HYSYS hydrate utility to be some what unreliable.
Another aspect that needs to be looked into, is that when methanol is used as a hydrate inhibitor the vaporization losses to the gas phase need to be considered and added to the methanol consumed for hydrate prevention. The vaporization losses can be read based on the final gas pressure and temperature from the chart (Figure 20-51) given in the GPSA engineering databook, 11th Edition, SI units.
I have developed a spreadsheet for Hydrate Inhibitor Injection calculations and if you provide me the following inputs I can calculate and inform you the injection quantities for both methanol & MEG:
Gas flow rate in SCFD or SCMD
Upstream (Higher) Gas Pressure
Upstream (Higher) Gas Temp.
Downstream (Lower) Gas Pressure
Downstream (Lower) Gas Temp.
Gas Composition or gas specific gravity, preferably gas composition if the gas is sour and with high CO2 content
			Posted 03 August 2010 - 11:32 PM
Please find the data
Gas flow rate : 6.5 MMscfd
Upstream (Higher) Gas Pressure : 255 barg
Upstream (Higher) Gas Temp:50 deg c
Downstream (Lower) Gas Pressure:45 barg
Downstream (Lower) Gas Temp.:10 deg C
Gas specific gravity:23
Stu
			Posted 19 September 2010 - 11:40 AM
Dear Sir,
Stu
Stu,
What you have mentioned as gas specific gravity is gas molecular weight.
Based on he data you have provided the MeOH injection rate (100% methanol) is 100 kg/day.
The MEG injection rate is calculated as 40 kg/day (80% aqueous MEG solution).
Hope this helps.
			Posted 29 March 2011 - 04:07 AM
Could you pls provide the hydrate calculation spread sheet.
vemparala.sastry@exterran.com
Rgds
Sastry
Dear Sir,
Stu
Stu,
Hope this helps.
			Posted 29 March 2011 - 04:31 AM
This spreadsheet is not for free distribution at this moment of time. If and when I decide to distribute I will post it on "Chereosurces" forum for everybody to download and use.
			Posted 11 February 2012 - 05:18 PM
moses
		 Gas Hydrate Inhibition: Calculations For Meg/methanol InjectionStarted by Guest_PYG_* , 30 Sep 2019  |
		Tail Gas Reactor TempStarted by Guest_Board operator_* , 17 Jun 2024  |
		Hydrate Formation Using Aspen HysysStarted by Guest_Hamza Almansouri_* , 10 Mar 2022  |
		 Heating A Low Temp StreamStarted by Guest_Geetanjali_* , 27 Jul 2021  |
		Hydrate Formation During DepressurizingStarted by Guest_Ghasem.Bashiri_* , 11 Aug 2021  |
