Power Generation Natural Gas
Posted 01 August 2010 - 01:13 AM
Posted 01 August 2010 - 01:45 AM
If you have sufficient gas available you can generate your own electricity (captive power plant) using Gas Turbines connected to a generator:
Have a look at the wikipedia article on gas turbines at the link below:
http://en.wikipedia....ower_generation
Another link outlines the basic principle of electricity generation using various means:
http://www.electrici...generation.html
This should give you a`start on using lean gas (predominantly methane) for gas turbines.
Additionally, if you can lay your hands on GPSA Engineering Databook, 11th edition, Section 15, "Prime Movers" a whole sub-section is dedicated to gas turbines which should provide you good guidance.
Your gas turbine system should be the first one built before the other units/plants receiving power from your captive power plant. Power during construction, commisioning & start-up operations may be derived from temporary sources such as large stand-alone diesel generators or engines which are readily available.
Hope this helps.
Posted 01 August 2010 - 07:52 AM
Patrick:
I think you are going about your solution in the wrong way.
Hydrocarbons are generally priced in one of two ways: fuel value and comodity value (market value). I believe you will find that propane and ethane are priced on availability and as a comodity first, since they tend to be more scarce. Natural gas should be cheaper or less expensive as a fuel (it is more readily available).
I would follow Ankur's advice and base electrical generation on natural gas firing.
Posted 01 August 2010 - 11:21 AM
As Art has pointed out, using C3+ as fuel gas is quite a luxury - you should be recovering these as liquid products and increase your profit margin. Very common configuration in remote locations is to utilize GTG's (Gas Turbine Generators) for producing power, and the most lean gas should be used for that purpose. Feed gas will be used for startup purposes only.
Here's a link to the GE website where you can ask for budgetary quotation: http://www.gepower.c...avy_duty_gt.htm or contact Siemens to see if any of their models fits your needs: http://www.energy.si...chuere_E_LR.pdf
Best regards,
Posted 01 August 2010 - 05:28 PM
Assmuing this will not be an issue, I shall burn some of the feed natural gas (consisting of approx 80%CH4, 13%ethane, 4%propane, 3%CO2, and small amounts of elements such as nhydrogen nitrogen etc.) in my turbine which I shall then have connected to a generator. Does anyone know of any lng process plants currently using this technique so i could have a look at the pfd and design details on the net?
Thanks for the help.
Posted 01 August 2010 - 10:56 PM
Feed gas is normaly used as the turbine fuel gas only during startup, i.e. when process discharge streams are not available yet. Depending on how much power you need for the plant + surroundings, you may have to burn additional quantities of Feed gas - but remember not to burn C3+ as these are the money makers.
The design information you are looking for is proprietary and as such not available on the internet. Some general information about the CoP Cascade process and the APX process from Air Products can be found on their websites.
Best regards,
Posted 03 August 2010 - 10:30 AM
patrickk,I shall burn some of the feed natural gas (consisting of approx 80%CH4, 13%ethane, 4%propane, 3%CO2, and small amounts of elements such as nhydrogen nitrogen etc.) in my turbine which I shall then have connected to a generator.
I would be a bit concerned over the large concentrations of heavier (than methane) hydrocarbons. I don't know what your process conditions are, but you may be in danger of generating some condensate, especially if you might start with moderate (ambient) temperatures and high pressure. Remember you will get temperature drops where you drop pressure. Key to successful operation of a gas turbine is keeping liquids out of the fuel supply. Besides disrupting the combustion process, they will wreck havoc with your environmental performance.
Posted 10 August 2010 - 01:34 AM
cheers
Posted 10 August 2010 - 02:26 AM
As far as energy is concerned, you will obtain the familly of curves (Power Output and Heat Rate) from the vendor, for range of ambient temperatures, humidities, etc.
See some interesting info at:
http://www.gepower.c...ct225_lorez.pdf
http://www.airproduc..._Is_Greener.pdf
http://www.airproduc...PS26Roberts.pdf
http://lnglicensing....nts/scaleup.pdf
#10
Posted 10 August 2010 - 02:30 AM
![]() Hello, Design Of Natural Gas Liquefaction Processes.Started by Guest_guoyinyanliner_* , 18 Jun 2025 |
Ammonia Line Vapor GenerationStarted by Guest_simadri_* , 07 Apr 2025 |
![]() Maximum Natural Gas Flow Through OrificeStarted by Guest_ukrche_* , 10 May 2024 |
