Resid Fcc -- Hydrogen Content In Coke
#1 suhas
suhas
  • 33 posts
Posted 13 August 2010 - 01:14 AM
What is the typical value of Hydrogen content in Coke for Resid FCC operation?
Thanks in advance
#2 Root
Root
  • 293 posts
Posted 19 August 2010 - 02:44 PM
Thanks in advance
Suhas,
Your question is not specific, if you are asking H2 contents in coke, this shold be nil and if you are asking about feed then you check what % of HC you are going to process. Eg C20 to C35 or lesser.
Toor
#3 suhas
suhas
  • 33 posts
Posted 19 August 2010 - 10:52 PM
Dear,
Question is very specific. Coke produced in the FCC is getting burnt in regenerator and that is coke always has some % of Hydrogen in it. There are various sources for this Hydrogen eq poor stripping of spent cat. For conventional FCC this number ranges from 7-8% hydrogen in Coke, I would like to know what is the typical value for Resid FCC.
Thanks in advance
Suhas
Thanks in advance
Suhas,
Toor
#4 Root
Root
  • 293 posts
Posted 20 August 2010 - 03:13 AM
Dear,
Thanks in advance
Suhas
Thanks in advance
Suhas,
Toor
Suhas-I have never seen H2 contents in RFCC coke. if you have some information and sources of information better to share on this forum.
Toor
#5 Himanshu Sharma
Himanshu Sharma
  • 172 posts
Posted 01 September 2010 - 01:51 PM
FCC heat balance is still one of the most complex areas in cracking reactions.
Refiners often use hydrogen-in-coke as a parameter to judge the performance of their fluid catalytic cracking (FCC) catalyst stripper.
As far as minimum range is concerned and industry accepted average of 5-6 wt% is accepted i.e. catalyst stripper is working the way it was designed to !
For maximum ,In order to define the upper reasonable limit for hydrogen-in-coke, you might consider a case in which a substantial amount of product is burned in the regenerator.
Burning the equivalent of slurry oil (main fractionator bottoms) in the regenerator as coke could be considered an extreme case. In this circumstance, the hydrogen-in-coke would be the nominal hydrogen content of a slurry oil with an atmospheric pressure ionisation (API) of ~01.
So you have a range between 5-6wt% to Hydrogen content of your slurry oil.(roughly around 9-10 wt % depending on type and quantity of residue being processed)
For calculating exactly analyze your flue gas composition and apply the equation provided in "Grace Davidson Guide to fluid cracking part one".(assuming your unit is not running on oxygen enrichment)
After having said this all i must warn you that most often people arrive at wrong conclusion because of Poor Flue Gas analysis
