Please let me know what is the philosophy behind the two check valve concept? When should we go for it & what are the types generally we use.?
Ajay
Double Check Valve.
Started by ajayd, Aug 14 2010 12:43 AM
Posted 14 August 2010 - 12:43 AM
Posted 14 August 2010 - 01:29 AM
Ajay,
Have a look at the links below. They should help you in understanding requirement of 2 check valves on the same line and the logic behind the fact that they should be dissimilar in operating principal (as an example one a plug-check type and the other a swing-check type).
http://www.usbcd.com...0513/13757.html
http://www.cheresour...ty-check-valve/
http://www.eng-tips....d=246849&page=7
http://www.cheresour...-valve-failure/
Hope this helps.
Hope this helps.
Posted 14 August 2010 - 01:42 AM
In brief:Increasing reliability against probability of valve failure.
