Is there any correlations for estimating the cost of Rectisol process? Any references containing base cost,base scale and scale factor would be appreciated.
Thank you.
Lurgi/linde Rectisol Process Cost Estimation
Started by chemengisfun, Aug 16 2010 09:30 AM
Posted 16 August 2010 - 09:30 AM
Posted 16 August 2010 - 09:52 AM
The following paper shows power/utility consumption for a typical Rectisol Unit. If you have process input data ready with you, the best idea is to contact Lurgi and ask for quotation. As said on few occasions already - if your company looks as a serious potential customer, Lurgi will provide you with basic process information and preliminary cost estimate.
Posted 16 August 2010 - 10:22 AM
chemengisfun,
In addition to the information Zauberberg ha provided the following links may help you further:
http://en.wikipedia.org/wiki/Rectisol
http://www.lurgi.com...8e_Rectisol.pdf
Hope this helps.
Hope this helps.
Posted 15 September 2010 - 02:15 PM
It's not so easy to scale a Rectisol unit. The capital costs are depending on many paramters (e.g. application, gasification type, feed pressure, composition, ...). So Zauberberg is right to contact the licensor company (Lurgi, Linde) if you want a cost estimation.
Midix
Midix
Going Through The Writing Process.Started by Guest_Haywardvek_* , 05 Jan 2025 |
Typical Process Of Platformate Splitter ?Started by Guest_AnbIran_* , 30 Dec 2024 |
![]() Process Gas Compressor - Capacity Control ValveStarted by Guest_CHSO4_* , 18 Jul 2024 |
Why Superheated Happen In The Crystallisation Process At 60DegcStarted by Guest_HSN202906_* , 08 May 2024 |
