Steam Recompression
Posted 17 August 2010 - 09:47 AM
Im investigating the possibility to take 10-25tons/hour of 25 psig steam and recompress it to 140psig.
Any ideas?
Posted 17 August 2010 - 11:53 AM
Posted 17 August 2010 - 01:47 PM
The equipment is cheap and reliable, but requires considerable experience to design successfully. Have a look at the Graham Manufacturing web site for info
http://www.graham-mfg.com/default.asp
Posted 17 August 2010 - 02:13 PM
If you compress saturated steam - you get water. You must have superheated steam so that the higher pressure does not condense the steam. You did not mention the temperature of your low pressure steam in your question, but it must be higher than the corresponding saturation temperature at the higher pressure.
Thanks for your reply joesteam,
I attached the file from the US Department of energy. They don't imply the need to have saturated steam, they even suggest to add a spray of water to eliminate superheat. The fact they post this article in the "industry best practice" I supposed it was a known process but my internet research on the subject did not give me much.
Your comment on saturated steam is thermodynamically correct but in the mechanical compression of air, most of the hp consumed by the motor is transfered in heat to the system. Maybe this would compensate for the saturation issue.
Posted 17 August 2010 - 02:46 PM
The easiest way to compress the LP steam is to use steam at a higher pressure than your target pressure in a venturi thermocompressor. This is very widely done and I (and I am sure many others here) have done this successfully.
Thanks Katmar,
Thermocompressors was my plan B. I do not have much details since I haven't visited the plant in question. I am still compiling all available technologies before answering to the customer. Thermocompressors do need higher value steam to operate and I do not know what they have available now. I was interested in the mechanical compression since the article from the US department of energy mentioned it as a best practice.
Posted 18 August 2010 - 06:36 AM
Posted 18 August 2010 - 10:05 AM
I am not expert on this, did a quick Google of 'Mechanical Vapor Compression', and the equipment uses an external energy source (electric or higher pressure steam) to reboil the water that condenses due to the higher pressure. You can't fool physics, saturated steam will condense at any pressure increase.
By compressing 25 psig saturated steam to 140 psig, the final temperature will be somewhere in between 305-325 degC, depending on compressor efficiency. Do we miss something here?
Posted 13 September 2010 - 09:24 AM
MVR(Mechanical Vapor Recompression) is done by turbo-compressor(=centrifugal type), however, multi-stage compressor is usually required.
Here in Korea, Samsung Techwin - air compressor manufacturer - initiated manufacturing steam compressor.
Anyway, you'd better look up MVR systems.
Edited by Jenergy, 13 September 2010 - 09:28 AM.
Posted 15 September 2010 - 09:45 AM
I hope following links may help a little,
http://www.spilling....ompressoren.php
http://www.energysol...compression.asp
http://www.thomasnet...17251604-1.html
Converting Superheated Steam To Saturated SteamStarted by Guest_addiesalsabil_* , 10 Sep 2023 |
