How To Determine A Tank Volume For Dissolution Of Soda Ash
7 replies to this topic
#1 Erwin APRIANDI
Erwin APRIANDI
  • 241 posts
Posted 19 August 2010 - 08:45 PM
Dear all,
Is there any one familiar with the step by step procedure of determining
dissolution tank volume?
The tank is required to dissolved soda ash to 25% weight solution
agitation will be provided in the tank
and the process will be on continous basis
  • 6,742 posts
Posted 19 August 2010 - 09:29 PM
HI erwin ,
Are you talking the dissolution of soda ash in water ?
http://www.fmcchemic...ge&handling.pdf
I 've experience with the preparation of a milk of soda ash ( water + light soda ash) where the Na2CO3 from a silo is fed to a reactor using a screw feeder . At the discharge of the screw feedder we have had a device to disperse the solid with water like a cyclone prior to enter the mixing tank .
Hope it helps
#3 Erwin APRIANDI
Erwin APRIANDI
  • 241 posts
Posted 20 August 2010 - 01:27 AM
Hi Breizh,
I already get the data, before
but my worries is wheter the residence time for the mixture
in the tank is enough or not
how you determine the volume of the tank, and how you
ensure that the mixing are complete. since my operation is
in continous operation and I want to make sure the outlet product is
constant as it effect the downstream operation
But it is a good idea to add the soda ash dispersion device at the inlet
I'll put that in the design
#4 breizh
  • 6,742 posts
Posted 20 August 2010 - 03:03 AM
Make sure you have all the data about solubility (25% seems high to me )
#5 Erwin APRIANDI
Erwin APRIANDI
  • 241 posts
Posted 20 August 2010 - 03:24 AM
Yes Breizh,
We are waiting for the dissolution rate data, to be provided by the chemical supplier
the 25% is not for the consumption but it will be dilute more to 10% before consumption
I think the saturation of soda ash solution it lies at around 32% so
we believe 25% is achieveable
Anyway can you give me some sketch regarding to the inlet device design?
my email address is erwin.apriandi@gmail.com
I was thinking that the device will be a conical shape
with powder inlet at the top bigger portion of the cone
and water inlet at side of the cone. and the mixture outlet
at the smaller part of the cone
By the way, I also trying to have this dissolution unit as a package
is there any vendor that you refer for this kind of unit?
#6 breizh
  • 6,742 posts
Posted 20 August 2010 - 04:01 AM
Erwin ,
Will try to find more data and will revert to you ASAP .For the design of the equipment you are right ( Liquid on tangent of the cylindric part( cyclone effect) and Product on the top (from screw feeder) .
For continuous process , consider to add a sensor to detect pluggage and stop the soda ash feed.
#7 breizh
  • 6,742 posts
Posted 23 August 2010 - 07:54 PM
Erwin,
Check your email.
#8 Erwin APRIANDI
Erwin APRIANDI
  • 241 posts
Posted 23 August 2010 - 08:42 PM
ok thank you breizh, it is very helpfull info
not it is clear how to start and design the system
