Boiling Point Using Hysys
Posted 27 August 2010 - 03:51 AM
Is there any utility in Hysys to find out the boiling point of a mixture or a single component?
Moreover, can we see the behaviour of boiling point of a single component or mixture with changing pressure (in the form of graph or something).
Thankyou
regards,
Posted 27 August 2010 - 04:09 AM
Posted 27 August 2010 - 05:55 AM
There is a utility in Hysys namely "Boiling Point Curves". I guess that is what you are looking for.
That doesnt help much, especially for single component
Posted 27 August 2010 - 06:42 AM
You can even find this data in Hysys' Basic Environment, by clicking on the selected component.
As for the mixture, you can use the data from Utility Tab, or you can create a simple flowsheet and evaluate IBP, 10%, 20% etc. volume flashed at different conditions by specifying stream conditions in Hysys.
Posted 30 August 2010 - 12:46 AM
Posted 02 September 2010 - 03:31 AM
Apart from the tools mentioned above, you can try case study as well.
- Define a stream using P-VF (pressure-vapor fraction) flash. Use VF=0 if you are looking for bubble point termperatures and use VF=1 if you are looking for dew point
- Add pressure and temperature of this stream in a case study (Ctrl+D)
- Use pressure as independent variable and define specific range and interval
All the best.
Edited by Chellani, 02 September 2010 - 03:34 AM.
Posted 03 September 2010 - 01:43 PM
Dear,Dear All,
Thankyou
regards,
I will answer your query one by one,
1. In case pure components boiling point (NBP i.e. @ 1 ATM. pressure), go simulation basis manager and in fluid package tab double click on selected fluid package and click on edit properties tab which will give all the properties of the single component (library as well as the pseudo component).
2. If you are in the simulation main environment and want to find out the boiling point elevation and suppression with respect to pressure for a single component, follow method suggested by other Che members i.e. define a stream and give composition(mole fraction) of single component as 1 and rest will be zero and then the VF as 0 and the Pressure which will give the bubble point at that pressure the same to be followed for a mixture.
3. When you need to find out the avg boiling point of a petroleum cut, follow API method-2B1.1 to calculate the different avg boiling points i.e. VABP(Volumetric Avg BP),MABP(Molal Avg BP),WABP(Weight Avg BP),CuABP(Cubic Avg BP), MeABP(Mean Avg BP).
Over and above if you need further help please let us know.
P.S. - Very soon I will upload an excel spreadsheet here for calculation procedures in API technical data book.
Posted 06 September 2010 - 09:57 PM
Thank you very much for your help
PS. PADMAKAR KEEPING FINGERS CROSSED FOR YOUR WORKSHEET
Posted 10 September 2010 - 06:08 AM
Thankyou
regards,
![]() Pipe Segment In Hysys Not SolvingStarted by Guest_Frya_R_* , 20 Jul 2025 |
![]() Teg Regeneration Hysys HelpStarted by Guest_connex_* , 17 Jul 2025 |
