Hysys Simulation Of Biodiesel Production
Posted 07 September 2010 - 06:00 AM
Im doing this simulation of biodiesel production using HYSYS. However, I get stuck in the methanol recovery distillation column, I get glycerol instead of methanol after distillation which enable me to conduct the methanol recovery. Can anyone kindly enlighten me about it? your help is much appreciated.
Thanks alot!
Hereby I post the link which lead to my simulation file
http://rapidshare.com/files/417601162/4_sept.hsc
Posted 08 September 2010 - 12:49 PM
I took a quick look and quickly fixed it for you. Your methanol stream is now 99.999% pure per mass basis.
If it is economical or not I don't know you have to find that out for yourself hehe.
I cannot upload this file for you so please send me your email and I'll email it to you. Otherwise here is what you have to do:
Delete all specs except distillate rate and reflux ratio.
Spec as follows:
Reflux ratio: 2
Distillate Rate 0.2701 kgmol/hr
That is all.
Posted 18 September 2010 - 09:59 PM
Posted 26 June 2012 - 01:34 PM
Have any of you finished the biodiesel plant design?. I am stucked also trying to solve the transesterification reaction. (NaOH/Methanol/triolein)
Please, if someone has the Hysys file of the design. Kindly send it to my email... eduardoabasolo@gmail.com
Best Regards.
E.A
Posted 28 March 2013 - 02:16 AM
Hi Guys,
i am also trying to design the biodiesel plant in HYSYS. but i strucked. if any one have file ( even if not completed).. please send to my ID easrikrishna@gmail.com. i will try to complete the file and forward you again...
Please Help.
Thank you..'
KRISHNA
Posted 14 April 2013 - 07:17 AM
Hey there,
Spec as follows:
Reflux ratio: 2
That is all.
Dear saidar
can u please upload hysys softwear if possible
thank you
![]() Syngas Plant SimulationStarted by Guest_kaidlut_* , 28 Jun 2025 |
Dynamic Simulation - SeparatorsStarted by Guest_tomr91_* , 10 Mar 2025 |
