What Are The Factors Affecting Mass Transfer Coefficient?
Posted 07 September 2010 - 11:33 AM
I'm wondering what the factors affecting mass transfer coefficient are?
If in one system of cooling tower, the flow rate of air was varied while the flow rate of water was constant and the flow rate of water was varied whereas the flow rate of air was stable, should Ky term be the same in all cases?
Posted 07 September 2010 - 11:51 AM
Heat and Mass transfer characteristics of cooling towers are very beautifully explained in this article on "Cheresources". Enjoy reading at:
http://www.cheresour...ctowerszz.shtml
Hope this helps.
Posted 07 September 2010 - 12:53 PM
Polipo,
Hope this helps.
Yep, I know.
But I'd like to know whether the mass transfer coefficient should be constant or not.
Thanks.
Posted 08 September 2010 - 08:55 AM
Dear,Dear guys,
Find the attached file here. I am sure it will solve your doubts.
Posted 08 September 2010 - 10:56 AM
An other resource .
Hope this helps
Posted 08 September 2010 - 11:50 AM
Mass transfer coefficient depends on reynolds number and schmidt number. These two in turn depend on mass flux, liquid density and viscosity, droplet diameter.
However, as explained in the attachment, Lewis correlation for air-water system simplifies calculation as ratio of heat and mass transfer coefficient is constant and we do not need to calculate HTC and MTC separately.
Sachin Anjan
Steam Methane Reforming Mass BalanceStarted by Guest_buskivi_* , 05 Jan 2025 |
![]() Constant Volume Vs Constant Mass Flow Of Centrifugal CompressorsStarted by Guest_panoska_* , 18 Nov 2024 |
Maximum Mass Flow In A Shell & Tube Heat ExchangerStarted by Guest_DonStalke_* , 22 Sep 2024 |
