I'm trying to make a temperature profile along condensing tubes containing a little noncondensing gas, and I'd like to get your assistance to make it.
I think steam without air may be ideal, real steam contains more or less air.
Therefore condensing temperature of the steam under constant pressure cannot be a saturation point, but a range of dew points below pure saturation temperature. (Condensing of binary vapor mixture)
Suppose steam with a little air is condensing in tube side, and water is boiling outside tube(shell side), each 1-pass stream.
Although tube inlet temperature may close to pure steam saturation temperature, however, condensing temperature decreases along tubes with decreasing partial vapor pressure of steam. And, If tube length is long enough, tube outlet condensing temperature will arrive at the minum approach to boil shell side water.
Condidering above process description, I think fully long tube length to arrive at min. outlet approach temperature could be uneconomical because most of all the heat exchange occurs around pure saturation temperature(tube inlet part). I should decide tube length with tube outlet temperature under economical point of view.
Can anyone recommend documents or books presenting clear solution to this subject ?
Condensing Temperature Profile Containing Non-Condensable Gas
Started by Jenergy, Sep 10 2010 04:07 AM
Posted 10 September 2010 - 04:07 AM
Posted 13 September 2010 - 11:54 AM
Phenomenon of effect of air on steam is described in following link:
http://www.spiraxsar...ting-theory.asp
Exchanger design for condensing in presence of non-condensibles is covered in chapter 13 of Process Heat Transfer by Kern, D.Q. An iterative solution for sample steam-CO2 system is also given.
In HTRI there is an option to indicate if inert gas is present in condensing stream (options tab menu). However, I am not sure if it takes into account both effect on heat transfer coefficient and LMTD. You can try that feature.
Sachin
Sachin
Posted 14 September 2010 - 11:08 AM
Process Heat Transfer by Hewitt,etal has a section on condensation curves. The Hand Book of Heat Exchanger Design has a section on "Single vapor with noncondesable gas.
Relieving TemperatureStarted by Guest_Falah_* , 01 Feb 2026 |
Sigma Profile For Cosmo-Sac In Aspen PlusStarted by Guest_R.t_* , 14 Aug 2025 |
Pipe Fluid Temperature Increase Due To Solar LoadingStarted by Guest_HeemeshJ126_* , 06 Apr 2016 |
