We have Stripper+ re-boiler in the amine system. There are two options to control the Over head temperature.
(1)In order to control Overhead Temperature we can reduce the area inside the re-boiler by adjusting the valve on downstream of the re-boiler.in this way the area will be reduced to decrease heat transfer
(2)We can have a bypass whenever the over head temperature need to be controlled we can use by pass valve to reduce or increase the hot oil flow.
Now the question is which option is more favorable. I am in the favor of option #1 because its cost effective.but at the same time does it effect the pump outlet pressure or can it cause back flow?
(2) Option is better for the process but costly. in this option flow is split. the only issue i have its costly.
I Have attached the drawing in order to understand the pressue corrrectly.
I need suggestion from you experienced engineers.
Thank you very much for your help.
