I want to know what's the different between a duluge valve and an on/off valve? In a plant for design the fire fighting sprinkler system I want to use an on/off valve instead of ADV (Automatic Deluge Valve), because I want avoid elaborating my design and decrease the cost. Would you please someone ansewer to me?
Deluge Valve
Started by Guest_gshahriar_*, Jun 28 2003 06:10 AM
Guest_gshahriar_*
Posted 28 June 2003 - 06:10 AM
Guest_Guest_*
Posted 15 March 2004 - 04:12 AM
If I`m right. I think you are shahriar gilanmorad.
i have got your answer just if you guess my name?
Posted 15 March 2004 - 03:07 PM
gshahriar:
If you're dealing with a fire-fighting design concept, I believe you are talking about the same valve, regardless of what you call it - even "mystery guest".
An "Automatic Deluge Valve" is simply a type of valve that:
1) is normally automatically actuated upon a fire alarm signal; therefore, it must be actuated by an appropriate actuator that is dependable and totally isolated from other power sources or dependencies that could jeopardize the ability to open when needed. In other words, if it is actuated by a pneumatic actuator, you must have a secure and reliable source for the air at the time of the need. Obviously, the signal and power source must be isolated from any fire.
2) has a minimal pressure drop characteristic and an ability to furnish all the design fire water flowrate at the minimum design firewater header pressure. In other words, you usually wind up using a full-bore, high Cv ball valve that fails in the open position. The valve must be capable of being tested and inspected while on stream 100% of the time in order to ensure that it is reliable and ready to act upon demand at any given time.
3) must meet the rigorous specifications of your insurance carrier. This probably is the toughest requirement (or it should be!).
I believe that covers the main scope of this valve. I'm open to hearing from other interested or experienced users/designers in the field.
I hope this helps.
I hope this helps.
Automatic Choke ValveStarted by Guest_Mudassssir011_* , 22 Jul 2025 |
