friends,
tell me different types of HE
difference between them
& most effective HE between the
give me detail info about HE
Types Of Heat Exchangers
Started by Suraj Pathak, Oct 10 2010 08:30 AM
Posted 10 October 2010 - 08:30 AM
Posted 10 October 2010 - 09:17 AM
Suraj,
Read through the following textbooks:
Process Heat Transfer by D. Q. Kern
A Heat Transfer Handbook by John H. Lienhard
Heat Transfer by J. P. Holman,
Additionally the following web links should help:
http://en.wikipedia..../Heat_exchanger
http://www.scribd.co...Heat-Exchangers
http://www.tpub.com/.../h1018v1_69.htm
You will definitely have to take the pains of reading what has been mentioned above.
Posted 10 October 2010 - 10:04 AM
y counter current HE more efficient than parallel flow HE
Posted 10 October 2010 - 10:50 AM
Suraj,
Have a look at the following:
http://www.ewp.rpi.e.../experiment.pdf
Don't use SMS language. This is an engineering forum and SMS language is strongly discouraged.
Ankur
Ankur
