Distillation Column P&id
Posted 20 October 2010 - 03:03 AM
As part of my final year project, I have to prepare a P&ID for a distillation column that I have designed.
I was wondering if anyone knew where I could obtain samples of similar P&ID's which I can make reference to while designing mine?
The column is just an ordinary distillation column with a partial reboiler and a total condenser with operating temperatures up to 250C and pressures up to 350kPa.
Thank you for your help.
Posted 20 October 2010 - 03:16 AM
first list the process varibales & then you develop control loop, it is very easy task.
regards;
santosh_khopade@rediff.com
Hey guys,
Posted 20 October 2010 - 05:37 PM
Posted 21 October 2010 - 02:49 AM
It s better to change "partial reboiler" to reboiler. I think partial reboiler is meaning les.
Posted 22 October 2010 - 03:17 AM
I went ahead and did most of my P&ID and its nearly complete now.
Just thinking where should i put High High or Low Low alarms and include shutdown systems.
Not sure what conditions would constitute a shutdown as that would be a major set back for the plant.
One scenario that I found that could cause a shutdown would be a very high liquid level in the column as that would cause flooding of the column.
I guess the temperatures of the product streams (indicating product quality/composition) would also constitute a shutdown if it were to fall far below or above the expected value.
Not sure what else though.
Any ideas?
Thank you.
Posted 22 October 2010 - 04:30 AM
Posted 22 October 2010 - 09:35 AM
Edited by gvdlans, 22 October 2010 - 09:36 AM.
