Seized Compressor Crosshead Nut
#1 moh_diesel
moh_diesel
Posted 22 October 2010 - 01:58 AM
In reciprocating compressor (Dresser-Rand) model HHE-VG, My problem is the hydraulic crosshead jam nut has o-ring failure so it cannot dismantle it by hydraulic pressure andwhat are the precedures to solve this problem and thanks for your help.
#2 chimistul
chimistul
  • 3 posts
Posted 18 November 2010 - 02:25 PM
Try heating. It should work.
#3 Guest_Crossheadnut_*
  • guestGuests
Posted 10 February 2011 - 01:11 PM
Have you heard of the new Torqlite cross head jam nut tool? It is a hydraulic torque wrench that has a head that opens up so the tool can fit around the rod, then closes. You can now loosen and accurately torque any nut that has a rod or shaft running through it. The tool has a +/- 3% or torque value accuracy traceable to NIST. The tool also carries a LIFETIME WARRANTY! Please contact me if you are interested in any more data. I have attached a brochure as well. Regards, Jason Turner 954-658-6595 or jturner@torqlite.com
#4 Art Montemayor
Posted 10 February 2011 - 05:36 PM
Jason:
Thank you very much for this very useful and practical information! Our members can profit by making a copy of this information and keeping it in their files for future reference whenever they come across this type of problem.
I resisted replying to this query back in October because I didn't want anyone to do what I have had to do in two previous ocasions in the past (a very long time ago): use a pipe wrench on the piston rod.
I also would not resort to heating the nut. This can have hazardous metal stress problems. I have resorted to using a pipe wrench because I simply ran out of options and had to get my reciprocating compressors back on stream. This was back in the 1960's. I would not resort to doing this again - but if push came to shove, I would do that instead of heating the nut with a heating torch.
The tool you have revealed to us saves a lot of grief and eliminates a lot of safety hazards.
Thanks again.
