Hi all,
I'm interested in being able to calculate the liquid volume of a partially filled inclined vessel. Does anyone have any tools available that they'd be willing to share or point me in the correct direction if the tools are available on-line? Thanks for your help.
Doug
Vessel Design Question
Started by djack77494, Apr 16 2005 08:42 AM
Posted 16 April 2005 - 08:42 AM
Posted 16 April 2005 - 09:37 AM
Doug:
Go to:
http://www.xcalcs.com/
On the left-hand menu list, click on Vessels - Volumes - Sloped.
They have 3 vessel head options that you can select:
Dish --- which is for a vessel with dished heads
Ell ------ which is for a vessel with ellipsoidal heads
Emisph ----- which is probably a typo and means a vessel with hemispherical heads.
I hope this helps you out.
Go to:
Posted 16 April 2005 - 12:27 PM
Art,
I suspected you'd come through with an answer for this one. I went to the website, followed your suggestions, and got my answer. (Now what am I going to do with all this free time?)
Thanks,
Doug
Thanks,
Doug
Posted 17 April 2005 - 07:56 AM
Doug:
Now you can catch up on reading all the Wolverine Engineering Databook volumes regarding heat transfer. This stuff is good for killing boredom and leisure time.
Have a good day.
Have a good day.
![]() Scrubber DesignStarted by Guest_nasss_* , 07 Aug 2024 |
Batch Adsorption: H/d Ratio For Vessel SizingStarted by Guest_Victor_process_Engineer_* , 28 Feb 2025 |
![]() Heat Exchanger Network DesignStarted by Guest_Kakashi-01_* , 21 Feb 2025 |
