Hi all,
We all are using heat transfer correlations of Nusselt number to evaluate heat transfer coefficient.
But there are two conditions in laminar flows
1. Convection with uniform surface heat flux for circular tubes
From Incropera & DeWitt
NuD = 4.36
2. Convection with uniform surface temperature for circular tubes
For the case of constant surface temperature
NuD = 3.66So , for Actual heat heat exchanger with laminar flow
which condition out of constsnt wall temp or constant heat flux condition exist,
so we can use directly value of nusselt number corresponds to it
Constant Wall Temperature And Constant Heat Flux
Started by srvinay, Nov 13 2010 12:11 AM
No replies to this topic
Posted 13 November 2010 - 12:11 AM
![]() Pipe Fluid Temperature Increase Due To Solar LoadingStarted by Guest_HeemeshJ126_* , 06 Apr 2016 |
