Dew Point Calcualtion
Posted 15 November 2010 - 03:14 AM
I have to calculate the dew point of flue gas coming out from incinerator to the stack to maintain proper stack temperature..But i am not getting any proper formula to calculate it.If I am going to use Antonie's equation but not getting Antonie's constant for SO2 or NOx. Some body kindly help me out with proper formula as early as possible. I am badly need your help.
The flue gas composition is as follows :
SO2 - 18.5 ppm
NOx - 34.1ppm
CO- 7.4 ppm
Hydro carbon - 17.3 ppm
moisture content - 6.4 %
Posted 15 November 2010 - 04:47 AM
You may Google around for the subjects "cold end corrosion" or "stack gas (acid) dew point" and you'll find a lot of similar charts.
Posted 15 November 2010 - 07:59 AM
A flue gas dew point excel calculator is available at the following link:
http://www.ntes.co.k.... dew point.xls
Additionally also have a look at the following post:
http://www.cheresour...h__1#entry20756
These should help.
Posted 20 November 2010 - 02:05 AM
But sir I want an empirical formula not a calculator.please help me.
Posted 20 November 2010 - 06:27 AM
Did you take the trouble of having a look at the second link in my post. It provides the empirical equations given by two different researchers A. G. Okkes and Verhoff & Banchero for flue gas dew point (basically sulfuric acid dew point ). The acid dew point is the one which is of concern for any kind of stack since flue gas temperature at or below the acid dew point contributes to the acid corrosion of the stack.
Ankur,
Posted 22 November 2010 - 01:36 AM
I am working as process engineer in Indian Oil Corporation LTD. India and monitoring after SRU block.
SO2 - 18.5 ppm
NOx - 34.1ppm
CO- 7.4 ppm
Kerosene Flash Point TroubleshootingStarted by Guest_zuberattan_* , 25 Oct 2009 |
![]() Negative Pressure At High Point?Started by Guest_mychemicalromance0425_* , 17 Aug 2024 |
![]() Chemical Injection PointStarted by Guest_Lyne_* , 15 May 2024 |
Hydrocarbon Dew Point Control UnitStarted by Guest_BabRafiq1_* , 05 Apr 2024 |
Increasing Raw Natural Gas Dew PointStarted by Guest_lowrentstuff_* , 18 Sep 2023 |
