Help: Nitrogen Generation Process Simulation
Posted 15 November 2010 - 06:02 AM
Nitrogen generation process simulation
I´m plannig to simulate a process which takes air and finally Iwill obtain nitrogen. I don´t know the equipment that I need to simulate the process in HYSYS, really I only know basic things of HYSYS.
Could any of you help me with information, books, etc.
Best regards,
Posted 15 November 2010 - 07:53 AM
How anyone can simulate a process if there is no basic information about the technology used, and the equipment configuration? It's shooting in the dark.
You can do a small research on the internet and see what technologies are available for Nitrogen production from air: Membrane permeation, Cryogenic distillation, and Pressure-swing adsorption being commercially available processes. Essentially, only the cryogenic distillation of air can be truly simulated in Hysys.
See attached files for preliminary information.
Posted 21 November 2010 - 06:02 AM
Thankyou,Betty,
I am going to deal with cryogenic distillation of air that can be truly simulated in Hysys.
I didn't find more equipment!
Could You clarify more!?
In the Cryogenic Air Separation.pdf_ page 7_ there is only Separation columns
Posted 21 November 2010 - 07:12 AM
Also look at the following links:
http://www.5penginee...rseparation.pdf
http://www.che.cemr....ge_proj/air.PDF
Also look at the COCO/ChemSep sample PDF below.
![]() ![]() Syngas Plant SimulationStarted by Guest_kaidlut_* , 28 Jun 2025 |
[Research Request] Uc Berkeley Student Seeking Process Engineers For 1Started by Guest_SangyunKim_* , 10 Jul 2025 |
Ammonia Line Vapor GenerationStarted by Guest_simadri_* , 07 Apr 2025 |
Dynamic Simulation - SeparatorsStarted by Guest_tomr91_* , 10 Mar 2025 |
