Where To Put Spec Break?
Posted 30 November 2010 - 02:10 AM
Which one is the correct sequence to locate piping spec break??
pipe with spec A - flange - valve - flange - pipe with spec A - spec break - pipe with spec B
or
pipe with spec A - flange - valve - flange - spec break - pipe with spec B
And what is the reasons?
Because I've seen some P&IDs with both spec break location.
Thanks for your kind help.
Posted 30 November 2010 - 02:56 AM
Have a look at the following earlier post where I had provided an attachment for piping specification breaks. This should help you.
http://www.cheresour...3151#entry23151
Posted 30 November 2010 - 12:47 PM
Edited by Art Montemayor, 01 December 2010 - 10:32 AM.
Posted 30 November 2010 - 07:20 PM
Any explanation regarding to this drawing? (I attached the snapshot drawing from API 14 J)
Posted 01 December 2010 - 01:30 AM
IMO,the mentioned Dwg is just a schematic diagram and actually (e.g. an as built PID) you would see the breaking point to be started from the adjacent valve flange.@ Fallah: if that so, why does API put some sketch in API 14J page 19 that indicates the break is in the pipe?
Posted 01 December 2010 - 07:19 AM
Posted 01 December 2010 - 07:50 AM
Posted 01 December 2010 - 07:11 PM
Dear Ankur,Manchester,
I have two quick questions on your (very useful) doc:
1/ Section 10.1: Why is the low temperature spec break located at the inlet flange of control valve on the scheme?
2/ Section 10.2: Why is the low temperature spec break shown at the outlet flange of the block valve upstream the control valve?
Edited by sheiko, 01 December 2010 - 07:12 PM.
Posted 01 December 2010 - 10:51 PM
Dear Ankur,
Sheiko,
1. The first case 10.1 if handling a high pressure stream has a drain valve between the upstream block valve and the control valve.
This allows the draining of the trapped fluid (condensed gas or liquid) between the block valve and the control valve in case the upstream system is isolated. Any chances of trapped material attaining lower temperatures due to the downstream low temperature stream is discounted considering that it can be drained. Hence the spec break is shown at the inlet flange of the control valve.
2. The second case 10.2 does not have any drain valve to remove trapped fluid. Fluid can remain trapped and attain lower temperature in equilibrium conditions due to pipe conduction and hence the spec break shown at the outlet flange of the upstream block valve and also a minimum distance of 600 mm shown from the bypass isolation valve to the bypass throttling valve.
Hope this helps.
Edited by ankur2061, 01 December 2010 - 10:52 PM.
#10
Posted 02 December 2010 - 03:09 AM
Item 2/ Section 10.2: the text is saying "spec break at inlet flange of control valve"...might be an error?
Regards.
Edited by sheiko, 04 December 2010 - 05:54 AM.
Restriction Orifice And Correct Location Of Class BreakStarted by Guest_F.Sh_* , 06 Aug 2025 |
Off Spec Condensate Storage TankStarted by Guest_shekhar dhuri_* , 05 Sep 2013 |
Equipment Spec SheetsStarted by Guest_Ken Bicknell_* , 07 Jun 2023 |
Need Help About Design Spec In Radfrac Aspen Plus V11Started by Guest_tpplo_* , 11 Oct 2022 |
Design Spec Equivalent In Chemcad V7Started by Guest_CHEMSTRONG_* , 29 Apr 2022 |
