Cold Temperatures Upstream Of Blowdown / Start-Up Orifice
#1 SR22
SR22
Posted 30 November 2010 - 08:18 AM
I am looking for information on minimum distance requirement requirements between a blowdown or start-up (pressurisation) orifice and the upstream blowdown / start-up valve.
I am involved in the design of a gas import system (gas enters topsides at 134-147 barg and 5deg C) which will experience significant JT cooling on blowdown or start-up. These cold temperatures could pose problems with ice formation if allowed to creep back to the upstream valve and I have found some information suggesting that it is good practice to have at least 600mm between the orifice and the valve but do not have anything from an official standard - API, NORSOK, etc.
Can anyone offer any advice if this 600mm is acceptable or point me to any other relevant info?
Thanks.
#2 fallah
  • 5,019 posts
Posted 30 November 2010 - 01:42 PM
Thanks.
I think such above mentioned distance just included in "Engineering Practices" and not in official standards.
Anyway,the mentioned distance depends on the coldness intensity,duration,material,...and could be evaluated in each case.
#3 Zauberberg
Zauberberg
  • 2,728 posts
Posted 01 December 2010 - 02:44 AM
The only place where ice formation can take place is downstream of the orifice, due to large pressure drop and the J-T cooling effect. Pressure drop across the valve is usually quite small when compared to that across the orifice, and I doubt it can lead to ice formation unless the feed gas is already quite cold and contains water.
"Creeping back" of ice doesn't sound as a very much likely scenario to me.
