The McCabe-Thiele construction should be based on the internal reflux ratio, which can be estimated by the following equation derived from an energy balance around the top tray:
R internal = R external *( 1+ ( CpL * DeltaTsubcooling/molar enthalpy of vap))
Ref: Separation Process Principles By Seader & Henley
CpL refers to Liquid Phase Heat Capacity.
Should I use CpL at the feed temperature or at the bubble point for calculating the internal Reflux Ratio ?
Please explain.
