In our ammonia plant-2, we have activated MDEA system from M/s BASF for removal of CO2 from synthesis gas.
A part of methanol / organic matter generated in high-activity shift converters is present in the process gas inlet to CO2 absorption column. This methanol / organic matter produces some impurities in the activated MDEA solution. To cater for this, we have an option to install a charcoal filter in the activated MDEA system. This charcoal filter will work on a slip stream.
Can readers offer any suggestion or share experience, if any.
Basf Activaed Mdea Process
Started by Azam, Jun 30 2003 11:06 PM
No replies to this topic
Posted 30 June 2003 - 11:06 PM
![]() How To Estimate The Circulation Rate For Amdea (Mdea 45Wt + Pz 5Wt) BeStarted by Guest_tokotof_* , 29 Nov 2024 |
Going Through The Writing Process.Started by Guest_Haywardvek_* , 05 Jan 2025 |
Typical Process Of Platformate Splitter ?Started by Guest_AnbIran_* , 30 Dec 2024 |
![]() Process Gas Compressor - Capacity Control ValveStarted by Guest_CHSO4_* , 18 Jul 2024 |
