Most visibly, metal ions react with soaps and calcium-sensitive detergents, hindering their ability to lather and forming a precipitate-the familiar "bathtub ring". Presence of "hardness ions" also inhibits the cleaning effect of detergent formulations.
Second, calcium and magnesium carbonates tend to precipitate out as hard deposits to the surfaces of pipes and heat exchanger surfaces. This is principally caused by thermal decomposition of bi-carbonate ions but also happens to some extent even in the absence of such ions. The resulting build-up of scale can restrict water flow in pipes. In boilers, the deposits act as an insulation that impairs the flow of heat into water, reducing the heating efficiency and allowing the metal boiler components to overheat. In a pressurized system, this can lead to failure of the boiler.
Third, the presence of ions in an electrolyte, in this case, hard water, can also lead to galvanic corrosion, in which one metal will preferentially corrode when in contact with another type of metal, when both are in contact with an electrolyte. However the sodium (or potassium) ions released during conventional water softening are much more electrolytically active than the calcium or magnesium ions that they replace and galvanic corrosion would be expected to be substantially increased by water softening and not decreased. Similarly if any lead plumbing is in use, softened water is likely to be substantially more plumbo-solvent than hard water
Ion-exchange resin devices
Conventional water-softening devices intended for household use depend on an ion-exchange resin in which "hardness" ions trade places with sodium ions that are electrostatically bound to the anionic functional groups of the polymeric resin. A class of minerals called zeolites also exhibits ion-exchange properties; these minerals were widely used in earlier water softeners. Water softeners may be desirable when the source of water is a well, whether municipal or private.
Sewage flows from the original area into the septic tank where the heavier solids settle to the bottom forming a sludge deposit. Lighter solids, such as grease, float to the top and form a scum layer. The liquid flows from the septic tank into an absorption system where it soaks into the soil. This process provides treatment of the sewage by gravity settling and skimming, biological decomposition and soil filtration. Proper functioning of an individual sewerage system depends on adequate design, proper construction, careful use and maintenance.
Today, we need science-based solutions reflecting expertise in environmental engineering, technology, regulatory issues, design and project management.
The best approach is to find a single source for these services. This streamlines the work process, maximizes your performance, extends your budget furthest and ensures greater accountability
Resins are also available to remove carbonate, bi-carbonate and sulphate ions which are absorbed and hydroxyl ions released from the resin. Both types of resin may be provided in a single water softener.
