Dear all,
We have a flow line of sour dry gas need to be purged, cut, and weld. The line is not pigable and it is spaded from one end and there is no provision of venting in this end. Spade cannot be removed because it required a total shut down. Flow line is about 4 km long and 8" diameter. Cutting and welding will be 2.5 km away from the purging point and about 1.5 Km from the spade.
The issue is: if we fill the line with N2 and pressurize to some extent, then bleed it from the same point, will it be sufficient purging? If not, what is the best way for purging? What is the N2 quantity required and how much we should pressurize N2?
It vey urgent job and appreciate your kind feedback on this issue.
