I am a currently 4th yr chemical engineering student. I was looking for some clarification on the use of dense or dilute pneumatic conveyors. I looking to transfer a very viscous/paste like substance over a horizontal length of 5m - 10 m and was having a few design doubts in relation to how feasible it would be. Will either of these set up with a vacuum or pressurised air set up through the pipe to carry the gel. From what I have research, wherever I have looked these systems are with powders and dense materials. I am unable to use a pump due to the very high solid content which will clog up the pump internals. Extrusion of the paste would not work either due to the material being temperature sensitive. The only other alternative is to manual transport the paste onto the next stage, however this results in uneaded handling issues and possible loss of product or contamination.
any advice would be greatly appreciated.
thanks
bob
Pneumatic Conveying
Started by bob789, Feb 05 2011 06:42 PM
Posted 05 February 2011 - 06:42 PM
Posted 06 February 2011 - 06:19 AM
bob789,
Have you heard of pipe belt conveyors or closed conveyor belts. They are utilized for conveying materials which are sticky and thermally sensitive and exposure to atmosphere would be detrimental to that material. Have a look at the following links. These should get you started:
http://www.pipeconve...Modern Belt.htm
http://www.pipeconve.../Papers/FAQ.htm
http://www.conveyorb...veyorBelts.html
Air Supply To Pneumatic HoistStarted by Guest_Im97_* , 25 Nov 2024 |
Sizing Pneumatic LineStarted by Guest_kangas_* , 04 Nov 2021 |
Pneumatic Pump For The Sulfuric Acid(98.5%) ServiceStarted by Guest_JKM_* , 17 Aug 2019 |
Constant Rate Drying Equation During Flash/pneumatic DryingStarted by Guest_cheminst_* , 20 Jun 2019 |
Solenoid Vs Pneumatic ActuationStarted by Guest_EngLearning_* , 29 Jul 2019 |
