Please check the attached drawing for better understanding of the case. The overpressure protection device is in parallel with two valve ( with same actuator). Normally, offgas goes to incinerator. If there is problem with incinerator or if pressure on suction side of blower is > 20mbar, the valve will switch to stack automattically. The overpressure protection device is designed to give additional protection again the condition in which the valve can not be switched to stack for some reason.
The pipe is plastic lined with Fiber reinforcement.
1: how to set Pressure at which overpressure protection device can be activated to ensure pressure on suction side of blower does not exceed certain value, say, 50mbarg (blower is VFD controlled by pressure on suction side). The plant process parameters showed that there is really no linear correlation between pressure on suction side of blow and discharge side where the overpressure protection device is located.
2: Basically, there are two approaches to the design. One way is to use pressure relief valve as used in tank overpressure protection.But as indicated above, the set pressure of relief valve is not easy to define at a fixed value, and once the relief valve is activated, it should be taken offline to recalibrate, which is not possible because it requires shutdown. The other, as preferred by plant people, is to use liquid seal vessel with some liquid inside to use hydraulic seal leg of certain height to protection against overpressure.
That's basically the background for my assignment. Please give comments and I will along the way provide more information which maybe valuable to find final solution.
