Hello.
I need some help with Hetran model for heat exchangers in Aspen Plus. I need to simulate a the behavior of a BEM type condenser.
I use Aspen Plus. I've chosen a Hetran model of equipment and inserted all of the information, that i have about the geometry of a condenser and the process it self, in Hetran simulation window inside Aspen Plus. In other words, i'm trying to run Hetran inside Apsen Plus interface.
When i do this a press "run" button, i get a lot of errors. Some of them are about the work not being defined.
What must be done to run Hetran inside Aspen Plus successfully?
Thank you very much!
PS: i can run Hetran outside Apen Plus, that's why i think that it has nothing to do with a license problem.
B-Jac (Hetran) In Aspen Plus
Started by antnfedak, Mar 01 2011 10:06 AM
Posted 01 March 2011 - 10:06 AM
Posted 05 May 2011 - 03:20 AM
Hi
First thing is that HETRAN has been sunset by Aspentech so it is better to use Aspen SHell & Tube Exchanger which is the new software.
For the HETRAN make sure the case works outside Aspen+ then import it. Also make sure that the definition of the HX is correct, are you doing a simulation/rating/ design what is the spec?
Kind Regards
Kind Regards
Edited by jcazenave, 05 May 2011 - 03:22 AM.
Posted 25 May 2011 - 12:24 AM
Maybe some settings in your Hetran browser (within Aspen Plus) are incorrect.
If you are rating a vacuum condenser, it can be the pressure drop is too high. (Please try BJM or BXM.)
Also, you may experience temperature cross problem. (Please check the temperature profile.)
At last, your specification of the condenser may be illogical or not attainable.
If you can elaborate your problem, our forum members may offer better help.
xavio
xavio
![]() ![]() Centrifugal Compressor Performance Curves In Aspen HysesStarted by Guest_Rafcio_* , 14 Mar 2024 |
Sigma Profile For Cosmo-Sac In Aspen PlusStarted by Guest_R.t_* , 14 Aug 2025 |
How To Model The Bitumen In Aspen Plus?Started by Guest_engrbab01_* , 28 Jul 2025 |
