1. Calculate the enthalpy at the starting temperature Ti of each component in the feed by adding H-H(298) of the compound and subtracting H-H(298) of the elements (with correct coefficients).
2. Sum these enthalpies. This is H(f).
3. Calculate or estimate a product composition.
4. Start an iteration by guessing a product temp Tf.
5. Calculate the enthalpy at this temperature Tf of each component in the product by adding H-H(298) and subtracting H-H(298) of the elements.
6. Sum the product enthalpies. This is the trial H(p).
7. Compare H(f) and H(p). Most likely they will differ.
8. By trial and error (or better, by clever algorithm) calculate an improved product temperature.
9. Loop back to 5 until H(f) and H(p) are nearly the same. The temp that gives equal H(f) and H(p) is the final temp.
I've tried this with N2/H2/O2 to make N2/H2O, and also with N2/H2S/SO2 to make sulfur in N2. But my calculated product temperatures are always too high. What am I doing wrong?
The water and sulfur examples are attached.
Ed
