hi dears
i want to know about the latest research areas on cheap processes for water purification techniques. the topic should be comprehensive and related to both industrial and domestic application. as most of you know that the water shortage and supply of clean cheap water is one of the hot issues all over the world , especially in south asia. th e help in this regard would be highly appreciated.
imran reza.
imranreza@gmail.com
Water Purification Techniques
Started by asim_umer, Jun 13 2005 12:50 PM
Posted 13 June 2005 - 12:50 PM
Posted 09 March 2011 - 04:47 AM
Hello Imran,
Check-out a solar purifier called Waterward which uses glass panels where the water passes through a series of cascading trays, the sun shines through the glass into the water. The sun’s radiated heat rays are partially absorbed by the water and then more completely by the black specialist plastic panel of cells. The heat is then conducted to the water which vaporises and condenses on the underside surface of the glass and then runs down into the purified water collection channel.
Working at an ambient temperature between 35°C and 40°C, the water within the Waterward is heated to more than 85°C. This pasteurizing effect partially kills bacteria and pathogens dramatically reducing the risk of water borne diseases. Prolonged exposure to the sun’s ultra violet light simultaneously transmitted by the special glass cover completes the germ killing process Their website is http://www.sunsurewater.com/.
I do not own the company, nor work for it. I just liked the simplicity and effectiveness of the idea.
LRS
LRS
