Relative Volatility Calculation In Hysys
Started by lqminh, Mar 24 2011 08:23 AM
Posted 24 March 2011 - 08:23 AM
I have some problem in the case of calculating the relative volatility of each component in Hysys. I do not know how to find it. This is the feed condition. Plz help me. Thanks.
Temperature: 3.2 oC
Pressure: 30 bar
Flowrate: 4285 kgmole/hr
Feed composition (mole fraction):
CO2 : 0.3641
Dimethyl ether: 0.6081
Methanol: 0.0278
Temperature: 3.2 oC
Pressure: 30 bar
CO2 : 0.3641
Methanol: 0.0278
Posted 24 March 2011 - 09:30 AM
I'm assuming this is in your textbook somewhere. Definition of relative volatility: alpha(i/j)=K(i)/K(j), where K=y/x, where y is the vapor composition and x is the liquid composition. So the relative volatility is readily calculated once you obtain the vapor and liquid compositions. With the information given, a flash calculation seems like the natural approach.
Posted 24 March 2011 - 10:28 AM
Really thanks a lot
![]() Pipe Segment In Hysys Not SolvingStarted by Guest_Frya_R_* , 20 Jul 2025 |
![]() Teg Regeneration Hysys HelpStarted by Guest_connex_* , 17 Jul 2025 |
