dear viewers!
i' m having a problem in hydraulic calculations of thermosiphon reboilers, any one having the idea of thermosiphon working criteria, please assist me...
Sohail Malik
Horizontal Thermosiphon Reboiler
Started by malikch06, Apr 28 2011 05:48 AM
Posted 28 April 2011 - 05:48 AM
Posted 28 April 2011 - 10:17 AM
In absence of any corporate (process) design standards, I'd suggest you to obtain at least one of the following resources:
1. D.Kern, "Process heat transfer"
2. E.Ludwig, "Applied process design"
3. R.Serth, "Process heat transfer"
In addition to that, browse these forums - I remember a lot of topics dedicated to thermosyphon circulation.
Some help from Google:
http://tx.technion.a.../LECTURE_08.pdf
Posted 29 April 2011 - 06:46 AM
i'v studied ur linked article,, my concern is regarding the thermosiphon reboiler working criteria, which in this article is stated as:: the pressure drop due to frictional losses must be equal to or greater than the pressure drop due to the density difference(termed as driving force),
in common sense, driving force must be greater than resistive forces, but here the case is reversely stated,
please explain this ambiguity
Eng. Sohail Malik
Eng. Sohail Malik
Posted 29 April 2011 - 07:54 AM
Actually these two forces (the driving and the resistance force) are equal, in any point of time in reboiler operation. More heat --> more vaporization --> lower density in reboiler return line --> higher driving force, but also higher frictional losses due to increased flow through the reboiler. As simple as that.
Not sure what the author was thinking by this sentence, but the equations given - as long as you use the equation sign between the driving and the resistance forces - are correct.
Phe As ReboilerStarted by Guest_Chemeng40_* , 20 Feb 2025 |
![]() How To Replace Existing Reboiler With A Thermosyphon Reboiler In HysysStarted by Guest_tomr91_* , 04 Feb 2025 |
![]() Thermosiphon ReboilerStarted by Guest_Abdelrahman Tarek_* , 17 Sep 2024 |
![]() Horizontal Pump With Suction LiftStarted by Guest_Deep24_* , 02 Aug 2024 |
