Hi
Can anyone help me to find the efficiency of a heat exchanger with changment of phase ???
Thanks.
Heat Exchanger Efficiency
Started by maxo, May 18 2011 08:24 AM
Posted 18 May 2011 - 08:24 AM
Posted 18 May 2011 - 10:15 AM
Thermal efficiency is a ratio used in calculating the LMTD correction factor. It is called the variable P.
P = (t2-t1)/(T1-t1). If there is a change of phase at constant temperature, there is no need to calculate P. The LMTD correction factor is 1.0.
Posted 19 May 2011 - 08:37 AM
Thanks a lot.
