Convective Heat Transfer Outside Of A Pipe
#1 jonlin
jonlin
Posted 25 May 2011 - 08:50 PM
Hi all,
I am trying to establish if a cooling leg is long enough. I am trying to calculate the overall heat transfer coefficient of the pipe. I can easily get the convective heat transfer coefficient inside the pipe, the conductive heat transfer through the pipe wall, however I am having some difficulty getting the external convective heat transfer coefficient.
The only item I am missing to complete my calculations is the Reynolds Number. How do I calculate the Reynolds number of air outside of a pipe? I suspect I need to use the hydrualic diameter, however all the literature sources only seem to show me how to calculated hydraulic diameter for internal pipe flow. I need to calculate it for external flow over the pipe.
Thanks all!
  • 6,742 posts
Posted 25 May 2011 - 11:37 PM
For natural convection , you can use the correlation from Lorenz :
Nu =0.55 *(Gr*Pr)^.25
Hope this helps
#3 jonlin
jonlin
Posted 26 May 2011 - 12:34 AM
Thanks Breizh,
I am actually factoring in wind passing over the pipes at a known velocity. Hence I think forced convection would apply in this case.
#4 srfish
srfish
  • 408 posts
Posted 26 May 2011 - 09:02 AM
There is a section in Process Heat Transfer by Serth that uses the pipe diameter for calculating a Re number. The section is " Forced Convection in External Flow". It starts on page 2/62.
