I am looking for practical knowledge from the experts on this topic. Co2 present in the fluid content
will cause corrosion, but to what extent depends on its percentage. Say I have 2%-3% of co2 in natural gas composition,
does one needs to do a detailed analysis to say it will cause corrosion?
Co2 Content In Natural Gas
Started by awesome, May 29 2011 02:01 PM
Posted 29 May 2011 - 02:01 PM
Posted 29 May 2011 - 02:38 PM
Awesome:
Contrary to what you state, CO2 DOES NOT CAUSE ANY CORROSION. I have piped and transported CO2 using carbon steel equipment as well as copper and brass pipe and never experienced (or heard of) any corrosion taking place. Where have you seen or heard of any CO2 corrosion - and under what conditions?
Now, CO2 in the prescence of liquid water will cause corrosion - mainly because it is no longer pure CO2, but rather "carbonic acid". Is that what you mean to write about? However, you don't mention water in your gas mixture, you only say natural gas + CO2. If the mixture is without water, I would not expect any corrosion problem.
Posted 29 May 2011 - 11:09 PM
Apologies consider water as well as Natural gas from wells is never dry.
Posted 30 May 2011 - 12:39 AM
awesome,
CO2 corrosion in wet natural gas is basically a function of the partial pressure of CO2 in the gas. NORSOK M-506 is a recommended practice for the evaluation of CO2 corrosion.
Additionally refer the link below for some guidelines on CO2 corrosion:
http://www.corrosion...nference-14.pdf
Hope this helps.
Hope this helps.
![]() Hello, Design Of Natural Gas Liquefaction Processes.Started by Guest_guoyinyanliner_* , 18 Jun 2025 |
![]() Achieving Ultra-Low Water Content (<0.1 Ppmv) For Pipeline PiggingStarted by Guest_Finchh_* , 21 Aug 2024 |
Water Content Of CondensateStarted by Guest__1angelia23_* , 10 Jul 2024 |
Analysis Of Ammonia Content In EthyleneStarted by Guest_Movers_* , 04 Jun 2024 |
![]() Maximum Natural Gas Flow Through OrificeStarted by Guest_ukrche_* , 10 May 2024 |
