It is feasible if I estimate 0,3 bar for pressure drop across a PCV (wide open 90%). If not, how much is OK?
flowrate = 6.5 MMSCFD
Thank you
Edited by eastorca, 02 June 2011 - 02:38 AM.
Posted 02 June 2011 - 02:29 AM
Posted 04 June 2011 - 11:12 AM
A PCV is just a control valve. Criteria for ΔP at (max) normal operating flow differ somehow from practice to practice; according to one of them, ΔP is the greatest ofIt is feasible if I estimate 0,3 bar for pressure drop across a PCV (wide open 90%). If not, how much is OK? flowrate = 6.5 MMSCFD
Posted 05 June 2011 - 10:06 AM
Edited by Kat, 05 June 2011 - 10:57 AM.
Posted 15 September 2011 - 10:27 AM
