Dear sirs,
Please guide what is the use of quality -1 and quality-2 curve in phase envelope in Hysys.
How to use this.
Kasri
Use Of Quality-1,quality-2 Curve In Hysys Phase Envelope
Started by kasri, Jun 02 2011 07:30 AM
Posted 02 June 2011 - 07:30 AM
Posted 05 June 2011 - 02:48 AM
I am not familiar with your simulator and I may be wrong but I guess that quality means a specification (for example a line at specified liquid fraction), this is useful when plotting a phase diagram, see for example "http://www.prode.com...seenvelope.htm" for a free sofware
Posted 06 June 2011 - 03:13 AM
... quality means a specification (for example a line at specified liquid fraction),
Pretty true, except it is vapor fraction (VF) rather than liquid fraction. Providing input for quality would give you flash results between bubble point (VF=0) and dew point (VF=1).
Posted 17 June 2011 - 08:51 PM
If you wanted to know the range of conditions when a given percentage of your stream has condensed or vapourized, this is a useful tool...
Posted 23 October 2012 - 09:15 AM
Old topic, but just what I was interested in.
Does this mean that setting quality to 0.1 equals 90% by volume?
Is it possible to change the basis, for instance to % by mole?
Posted 23 October 2012 - 11:10 AM
generally you solve phase equilibria for a specified molar fraction of gas or liquid phase,
(at least my copy of Prode Properties does that but different tools may add some other features)
for real fluids you must consider Z (compression factor) or equivalent parameter when converting,
for example to convert component i in the mixture from mole fraction to volume fraction
xvi = zi * xmi / SUM(zi*xmi)
hoping this helps.
hoping this helps.
Edited by PaoloPemi, 23 October 2012 - 11:12 AM.
![]() Pipe Segment In Hysys Not SolvingStarted by Guest_Frya_R_* , 20 Jul 2025 |
![]() Teg Regeneration Hysys HelpStarted by Guest_connex_* , 17 Jul 2025 |
Three Phase Seperator ModificationStarted by Guest_halkeshhulk_* , 10 Jun 2025 |
