Dear all,
i have first assignment on calculation compressor performance.
one of parameter compressor performance is head.
Do you know what is head?
and after i calculated, head has unit in meter.
what the head show?
thanks all
Compressor Head
Started by minyi, Jun 03 2011 12:50 AM
Posted 03 June 2011 - 12:50 AM
Posted 03 June 2011 - 01:05 AM
minyi,
The following links should help:
http://en.wikipedia..../Gas_compressor
http://en.citizendiu.../Gas_compressor
http://www.leconsyst...t-RakeshMat.pdf
Posted 08 June 2011 - 05:03 AM
Hey Ankur,
This links are reallly helpful... Thanks a lot...
Regards.
Regards.
Posted 20 June 2011 - 01:33 PM
http://www.cheresour...gal-compressor/ is a thread of Cheresources to explain centrifugal compressor polytropic head. It seems that meaning of mentioned head is work exerted per unit mass of the gas (dimensions M^2/L^2), not meters of fluid as in a pump.
Last Web reference, reported by Ankur in his post, gives a formula for head having dimensions as above.
Edited by kkala, 20 June 2011 - 01:42 PM.
Centrifugal Compressor Cmpression Ratio /discharge Temperature LimitStarted by Guest_Lyne_* , Today, 03:11 PM |
Compressor Selection Based On Flowrate & Compression RatioStarted by Guest_Dhams_* , 19 Jan 2026 |
Purge Gas For Centrifugal CompressorStarted by Guest_Lyne_* , 19 Oct 2025 |
Igv Control For CompressorStarted by Guest_Lyne_* , 30 Aug 2025 |
