A non expert trivial view, hoping of more effective help.
1. Pump head is about 11 bar, so its normal discharge pressure could be about 11+8 = 19 barg (plus static head from LNG tank). After start up it develops 98 Barg in 10 s, so there must be water hammer in the discharge line (8" to vaporiser & 6" of kickback flow).
2. TRV set pressure is 148.4 barg, so we would expect no flow in the 2" line even during pump start up. Yet vibrations in this line indicate flow at rather excessive rate (neglecting resonance). Vibrations may be intensified by the five elbows, assumed to be upstream TRV.
So either TRV set pressure is wrong, or developed discharge pressure is not 98 Barg but 148.4 barg or higher. The latter could expose piping in pump start up to pressures higher than design pressure.
You may check Thermal Relieve Valve (TRV) first (calibration, leakage), then measure discharge pressure at start up and see how to reduce water hammer (surge) at the discharge line, to either evaporator or to LNG tank (kickback is assumed to return there). The pressure increase is rather high, probably the reason can be traced. Water hammer analysis can quantify the results, but usually you have to locate the "suspect" first. Following merely concerns some thinking on it.
3.1 Pump shut off can be about 8+1.25x11~ 22 barg (plus static head from LNG tank); probably a start up with discharge valve closed, then gradually opened, could alleviate surge. Is this action realized by the "FC" valve? If so, the valve had better be at manual mode in start up, slowly opened. But why a valve at discharge is CSO?
3.2 If pipe is really full of liquid, chances of water hammer are reduced, especially at start up. You may want to verify whether whole pipeline is full before start up.
3.3 I assume that the shematic is simplified; there must be additional valve at discharge to justify the TRV. Check valves at discharge (if there are not) could alleviate water hammer, reducing back flow. This concerns mainly pump stop; but back flow may empty parts of the pipeline, when pump is idle.
3.4 If surge on discharge line is settled, most probably vibrations on the 2" line will disappear at start up. They may appear when the TRV gets in function, which will last few seconds to my understanding (as thermal relieve valves do).
3.5 It is agreed that present situation (isolating PRV in start up and bypassing it) is not recommended, even though TRV contribution to pressure relief would be insignificant (pump flow = 456 m3/h).
Edited by kkala, 15 June 2011 - 06:53 AM.
