For packed tower design, try the HETP approach
Assuming pure water, the partial pressure of 4% Ammonia at 20*C is about 3.5 KPa. Henry's law seems reasonably valid below this range.
For feed concentration of 100ppm or 0.01%, the partial pressure with Henry's law is 8.6e-5 atm. This means 8.6e-5 moles ammonia per mole of air is the equilibrium with 100ppm ammonia liquid. Converting to weight fractions, this is 5e-5 kg NH3 per kg of air.
Your waste water flow is 8,000 kg/h, containing 0.8 kg/h ammonia. The minimum air required (infinitely long column) for stripping ammonia is 0.8 / 5e-5 = 16,000 kg/h = Gmin
Since we cannot have an infinitely long column, take G=1.5xGmin = 24,000 kg/h. The operating curves are plotted in enclosed attachment. Four (4) theoretical plates are required.
The HETP of column packings is available in various literature (Ludwig, etc.). You can take the Norton Generalized formula ln HETP = n-0.187 ln(Surf.tension) + 0.213 ln (viscosity). n varies with packing size.
Column height for 2" PP Pall rings is approx. 1,000mm x 4 = 4,000mm column height.
The pressure drop correlation is the one you have used. For a 40mm/m pressure drop (Total 160mm drop) and 60% flooding, I got a column diameter about 1.6m.
Hope this is useful. Ammonia stripping is difficult when there is mild acidity, even dissolved CO2 in the waste water. You have to then consider lime dosing to neutralize the solution.
Edited by cnaren, 22 June 2011 - 11:55 PM.
