Thanks for the help!
Edited by fastjordy378, 21 June 2011 - 09:38 PM.
Posted 21 June 2011 - 09:37 PM
Posted 22 June 2011 - 11:36 AM
I'm assuming you are using the ideal gas law for this analysis. It is true that the P is directly related to n, so one might conclude that the vessel with more air in it has the higher pressure. However, the vessel with more air has a larger headspace (V is larger) and P is indirectly related to V. So, in addition to looking at how P is related to n, one also has to consider how P is related to V. The ideal gas law is a simple expression, so the algebra should be easy enough. I would suggest you walk through each state until you can best see how P is going to change.will the container with larger headspace, and therefore larger amount of moles of air in it, have a greater total pressure than the other one?
Posted 23 June 2011 - 10:36 AM
Edited by EyMiller245, 23 June 2011 - 10:37 AM.
Posted 28 June 2011 - 10:43 AM
Attached "conPress.xls" is an example suggesting an answer (subject to comments). Hopefully it helps.Lets say you fill two identical containers with different amounts of pure water, so that there are different amounts of headspace in each container. The containers are open so that the headspace is atmospheric air before sealing them. If you heat them to 150 degrees Celsius for instance, will the container with larger headspace, and therefore larger amount of moles of air in it, have a greater total pressure than the other one? Or will the total pressure be the same for both containers? I realize the vapor pressure of water is only a function of temperature and that it's the same for both containers.
![]() Recommended Installation Location For "pressure High" InterlocStarted by Guest_omupei_* , 20 Jun 2025 |
